I'd suggest you also submit a report to NHTSA. Maybe they will approve the US recall more quickly that way.I think this happened to me today...
Coming home from a 60 mile ride, I was almost to my house and started to smell something. I pulled into my driveway and realized there was smoke coming out from under the handlebars. I shut the spyder off and looked underneath and there was fluid dripping. There was a lot of white smoke billowing from every opening. I let it cool down for about an hour, then started it to pull it in the garage and almost immediately it started smoking again!
Also, the LCD read 'break failure'.
I guess I'll be contacting the dealership on Tues.
did ya pull the Tupperware to get that temp shot...that would have taken at lest 30 min.... or did ya just shoot the temp thru the Tupperware?I went for a ride today in my 2013 ST-S, when I got home for kicks I checked the heat around my master cylinder w/ a laser heat detector.
All around and underneath it was 104-106 degrees? Not near enough to cause any issue??
Just sayin'
My concern is what are they hoping to do? I know of one bike that has had the heat shielding done as well as master cylinder changed and is still having same heat issues. My brake switches went bad and all they did was to replace them. Nothing on the bike was changed. I still have heat issues and am waiting for something else to melt. Wish they could figure way to vent heat out to prevent this from happening. Will take mine in for recall and have work done but really wonder what end plan is. I have a bike I don't trust riding to work much less across states. Not bad for a 25,000 investment. Will keep fingers crossed.
My master cylinder on my ST-S can be seen pretty easy when I pop up my seat.
Maybe it is a little hotter underneath, but can't be much more one inch under where I measured?
Why are so many people saying this recall is not for the US? It most certainly
is, i have the print out. 2013 RT limited.. I guess some people like to fill a knowledge vacuum with hot air, from under their tupperware.
when you pop up your seat you are looking at the brake reservoir ...the master cylinder is under the Tupperware on the right side down near the exhaust pipe View attachment 74942notice the melted plastic...that is the master cylinder
