I get
ALL that ^^ guys, but the fact is that somewhere in the design process someone HAD to consider Camber, Caster, 'A' arm lengths, arcs of movement, the optimal torque & pre-loads for all the bushes & bolts & power steering sector arms & a bunch more stuff to do with suspension & steering geometry & design - & as shown by MurphyBrown & others, it would be
REALLY handy if that person/s let the rest of the world in on the secret of what all that stuff
SHOULD BE so all those parameters could be checked when things aren't working or steering right!!
The fact that they aren't
meant to be readily adjustable doesn't mean they will always stay exactly where they were put/set in the factory, & it seems no-one has ever questioned IF the factory actually got it right in the first place anyway..... which is odd, seeing that we all know there are just a few other things that don't necessarily leave the factory/ hit the road exactly the way they should?! And that's not even considering all the variations & movements that can/will occur on the road, what with different loads, different sized riders, different road profiles & surfaces - I'd bet that many of the steering & handling issues people express concern about can be traced back to 'inconsistencies' in alignment in the way their bikes left the factory & quite probably how all those 'other' but extremely important alignment specs & parameters have changed since....
But none of us can check that our front wheel & steering gear alignment is actually what it should be cos that seems to be a closely guarded secret at BRP that many riders just ignore as maybe being a part of their steering/handling problems because 'it's not readily adjustable so the manufacturer must've done it right in the first place & nothing I've done since could possibly make that change in any way'
:banghead::banghead:
I'd
REALLY like to know what BRP suggests the full wheel alignment specs & steering angles, pre-loads etc are
MEANT to be so I can make an informed decision about 'fixing' any of the supposed or otherwise handling &/or steering issues my Spyder may or may not exhibit now or at some time in the future, as I know that just general use on the road may well change any &/or all of them at some time....
