spyderfish
Alignment Gurus,
I have read a lot about Spyder alignments in this forum. There are many opinions, techniques, and suppliers that have posted a lot of information here. I have been reviewing this info and have a question, hopefully the knowledgeable folks here can give an accurate answer.
From what I understand, the only adjustment for wheel alignment are the 2 adjustments on the steering arms on each side of the Spyder? I believe these adjustments have limited effect on caster and camber, but are designed specifically to change the toe in?
Or, are there other adjustments in the front steering mechanism as well?
In addition, there is no rear wheel alignment capability, except making certain the belt tracks correctly on the 2 sprockets, true?
Thanx in advance,
Spyderfish
Thanx in advance,
Spyderfish
