WackyDan
The last couple of days on some short rides to the gym and errands I was getting a burned oil smell. Wrote it off to other traffic at first, but after today's ride I seemed to be getting it after taking some hard turns. Let me add, that one other perk of having the tall touring shield (CHAD) is that is seems to ensure that smell gets pulled up behind the shield and to my face... Go figure.
Spyder has 1200 miles on it so far.
After the reports of fires and now the other Spyder smoking, I decided to pull the plastic for the first time and inspect the airbox. Sure enough, there was oil strewn all inside and outside. Not a lot, but there were some areas in the airbox where it was pooling.
So... I guess I'm going to do the Lamont airbox mod...
Some questions:
- How tight do you put the torx bolts back in? I was being careful not to simple the plastic too much.
- Should I be putting locktite back on the torx bolts? There was some already on them.
- Some of the torx bolts had black plastic washers... some didn't... What's with that?
I also checked the 12volt outlet in the trunk that isn't working. Connections are fine... But man, trying to get the weather proof boot on the back of that thing is impossible without taking off the entire trunk, so that will have to wait till another time.
You'd think they could have made that airbox easier to get to eh?
Some questions:
