air pressure for winter storage
Dukester
I have the original tires, what tire pressure should you use to store for the winter. I have the tires on two layers of carpet and the carpet on fatigue mats for each wheel? Thanks for the thoughts.
I keep mine same as always--- 17 fronts and 27 rear-- then just put my atv lift under the bike and lift it up just enough so the tires are not touching the ground.....
I put 27 in the front and 32 in the rear but I,m not going to extremes as far as this goes. Normal 19.5 and 29 Pds.
tires
Whats the biggest concerns with the tires if I don't lift the unit off the ground. Like I said, I put fatigue mats and carpet under each tire. I will roll the unit a quarter each week. Is this needed to roll the unit? Thank you for your thoughts.
