JkRbbt
Hi Folks,
I have a "new" 2014 RTS that is having an engine overheat problem. First time I noticed the needle climbing was at 250 miles on the clock. But, just as I noticed, the needle went back to "normal" and I thought it was just a glitch. The next time it happened, I had just ridden about 180 miles the following week and stopped for lunch. As I was leaving town, a few blocks of stop and go traffic, the needle pegged out "HOT"! I pulled over and checked the coolant which is really difficult in bright sunshine on the side of the road. I couldn't tell the exact level, but there was fluid in the reservoir! Turned the key back on and the temp registered "normal," so we took off. Went about 40 more miles at "normal" and then she climbed back to "HOT"! I kept riding to see what she would do, and the needle would drop back to "normal", then go to the bottom of the "hot" arc, then peg, then back to "normal".
Took her to the Spyder doctor and he couldn't duplicate it, of course, but put about a quart of fluid in to top it off. NO evidence of a leak on the ground, on the engine, or anywhere else. (Question the setup procedure.) Last Monday, I rode about 200 miles and everything was "normal" UNTIL the last few blocks from home. The needle pegged out again! Checked the coolant and it was right at "full" for a hot engine. Took it back to the shop and they idled it for a 1/2 hr with no evidence of leak, temp normal, and did top off with a bit more coolant. The gent said that these engines do get "air in the system". My question to everyone with the 1330 is, have you ever heard of this. The motor, having been around for a couple of years now, I thought I would have heard of something like this if they are susceptible. Anyone else have a problem with the motor overheating or any indication problems? Feel free to chime in. I think my mech could use the help! Thanks!
