AIR FILTER COMPARE FOR HMF EXHAUST
Just so you know, you do not need to upgrade the air filter to run the HMF exhaust. I run the stock air filter and the Spyder runs great with it along side the 02 mod.
I might be wrong, but If you change the air filter it might make the Spyder run even more lean than it will already.
is there a post here that shows you how to do the o2 mod?
Its "plug and play" so pretty much a no brainer. You may have to hunt to find one though as Ken has dropped out of Spyder accessories at this time :(. You could try Custom Dynamics but if you get really stuck I can send you one from Oz. I have a few left.
It's really a easy install. Find the 02 sensor on the exhaust (in front of the rear tire) Follow wire up where the connector is (you must remove splash guard above rear tire). unplug 02 sensor, plug in 02 mod, remove 02 sensor from exhaust and screw in the plug that comes with the 02 mod, button everything back up and your done. 1/2 hour to 45 minutes install. :thumbup:
