Air compressor runs all the time - how do I go about disabling it?
I'm sorry MrBill, but if your compressor is cycling all the time, then it's almost certainly because you have a leak in the ACS system somewhere & disabling the compressor probably won't let you go manual anyway!! :gaah:
That leak or leaks may be in the 'non-return valve'; more likely be in the air bag itself; or most likely be in one or more of the 'push-fit' air line fittings.... You'll need to fix or bypass the leak/s before you can get any sort of working ACS again, even if you do want to go strictly manual! :lecturef_smilie:
Yup you can easily hear it hissing on and off, doesn't matter if you are on or off, moving or not. As long as the the engine is running you can hear it doing it's thing. Great, just great! It sounds like it's going to be a long afternoon tracking this down.
I thought my compressor was cycling also. But it was the DPS that I was hearing at low speeds. Check yours before tackling the compressor. Try a mechanics stethoscope to listen if you can, or tape a recorder in the area.
Dang thing will cycle whether you are moving or not and if you are on or not. As long as the engine runs, you can hear it and hear it a good distance.
MrBill, you have one of two problems. 1. A leak in the bag or system. 2. The compressor has failed. There is a set screw on the crank shaft that backs off. The compressor motor runs but, the piston will not pump air. I have replaced 3 compressors with this problem. One on my bike and two for friends. I have a video on YouTube showing how to install an after market compressor. Go to YouTube and search for Can Am Spyder Compressor. It's about 45 minutes long.
I need a little help here for my 2014 RT-S. The air damper does not hold air when filled manually and I'm not sure if there is a compressor or if it is running if present.
I'm going to be replacing the rear shock with an Elka from Lamonster. UDo I still need to have the damper operational with the new shock? I saw a review on Lamonster by a guy who just left his air damper disabled after installing the new shock. I don't mind saving $200 -$300 to leave it as is, but I don't want to be open to doing any damage to that $600+ new shock.
Anyone out there have any experience with this?
Need air compressor for 2014 RTL SE6 1330
I'm 99% sure my compressor in my 2014 RTL (1330) needs to be replaced so I'm looking for where is the best place to order one (price)? Any suggestions. Dealership sells it for $370.
Have you got down there with a bottle of soapy water and figured out where the leaks are coming from first? That's what I would do, then you know what you're fighting!
One thing is for sure - if you let the pump just run wild, it will burn up. But you have to know where it's leaking from first!! Good luck, it's in a sucky place to get to, it's too bad that you didn't need a rear tire, because taking that off would give you a lot better access to some of the parts! Good luck!! (y)(y)
Please tell how you found this and fixed it. Curious.
What is the DPS? I just purchased my first Spyder 2014 RT Limited. The rear suspension is not working. I bypassed the compressor and ran a line straight from the airbag to the Schraeder valve. Now I can hear a sound that runs for about 10 seconds, then stops for 5 seconds, and then continues this cycle. Is that compressor or DPS? Any help would be so appreciated.
The DPS is the Dynamic Power Steering, and it won't be running unless the steering is being moved, as it's an electrical assist for your steering. ;)
