Roadster Renovations
Just a heads' up. I had my airbag develop a pinhole leak on the bottom. Taking the bike apart I found the leak. Looking at how it was punctured, there were several small, sharp rocks that had gotten lodged in the bottom recessed area the bag rests in that rubbed a hole in it.
It is a great deal of work to remove it for cleaning, but what I will do from now on as my regular maintenance is to:
1. Bleed all the air off of the air bag.
2. Lift the rear tire off of the ground with a floor jack placed on the rear of the center beam. (the combined lack of air and unloading will stretch the bag as far away from the swing arm as possible)
3. Use a compressed air blow gun to blow any debris out of the dish the airbag sits in.
The location and design allows for any rocks kicked up by the rear tire to potentially land in that critical area, and in all truth I am surprised even more don't fail.
For the real wrenchers out there, you can even disconnect the air ride lever, using a floor jack unload most of the weight off of the rear shock bottom bolt and remove it. Using a 13mm loosen the bottom air bag bolt a few turns and support the swing arm with jack stands, raise the bike slightly. This will give you a chance then to get in around and really clean it well.
Hope it helps someone.
