Aggressive riding in the curves question
When you can't stay in the right lane on the curve - crossing into the on-coming lane. Unless you have a Daytona Spyder, Nanny will put you down onto the road before you can turn over. For many of us, the game is to see how fast you can take a curve before Nanny kick in. So you won't know where that point is until it actually happens.
I love to challenge Nanny. I haven't found her yet on my F3T.
Nothing about the Daytona is any different than the other Spyders. The Daytona isn't the only 2017 F3 with Sport mode. My F3-S has it. Sport mode does not turn the nanny completely off.
We both stress at work. For us going on a Spyder ride is time for relaxation, not wondering if this is the time the nanny doesn't work. We have ridden many roads that weve been on before, and it always amazes us of the sights that we missed in our cage. For us it's about living in our environment not seeing how fast we can get through it. Just my two cents.
Since "the nanny" has become an integral part of this discussion, I have a question regarding it's behavior:
On my F3-S D500 (SE model) I've never experienced nanny (while driving), nor have I ever disabled traction control. No need to IMO, because it must already be set rather "aggressive" on this machine/model, however:
Just realized yesterday that when I take corners and am riding fairly aggressively (at sub 50 mph speeds), I am frequently seeing the yellow traction control flashing. (Very seldom do I watch gauges, but I just happened to notice it once the other day. Looking for this I now realize it's fairly common for it to flash when I'm cornering aggressively/leaning into the corner like this. (Never cuts power or anything, just flashes.) I'm wondering whether this is the difference between the newer models and the older ones that didn't allow you to accelerate coming out of the apex.... (Nanny is more "permissive" in newer machines, but the warning still flashes?) ~ If wrong, could someone explain this?
I admit I was a skeptic but the BajaRon sway bar and metal links improved my ride quality by a large margin.
I don't think the metal Helm links actually improve your ride quality, Road-Kill. They are just a higher strength item than the stock BRP plastic links that can break. I am currently running one of each until I get the time to replace a faulty metal link. All works well and is OK by Ron.
That yellow light flashing means the Nanny IS intervening in some way!! :shocked:
It could be that she's just limited the spark rate or injection to keep power down a little, or that she's applied any one (or more) of the brakes to ensure that your Spyder can make the corner you've just asked it to thru the steering input you've got dialed in; the speed you are travelling at; what your speed, control input, & the road is doing to/telling all the sensors, & how much lean you personally have put in to keep everything stable; or she could be making any one or more of a whole raft of other little tweaks thru things like the ABS, EBD, DPS, VSS, etc.... all stuff that you may not have noticed the how or realise why she is doing what she's doing, but she definitely IS intervening & keeping things within the parameters she has been told are acceptable! :thumbup:
I suspect that very many of those who claim or think that their Nanny hasn't ever intervened simply haven't realised when she HAS!! It's just that she hasn't had to intervene in a heavy handed or clearly noticeable way, and she can be extremely delicate & discrete!! She is actually quite gentle in most of her applications, but you'd hafta ride your Spyder slower & gentler than a loaded hearse for her not to have ever intervened in some way & I really don't believe that too many actually ride like that - altho I will allow that you hafta push her limits & boundaries pretty damn hard for her to intervene in a manner that is noticeable to some! Still, whatever you do, however you ryde, she is always there & she is always watching - and she intervenes waaayyy more than many might think; they just haven't noticed her gentle touch keeping them safe & their Spyder under control! :dontknow:
NANNY INTERVENTION
:agree::agree::agree: .......in short the VSS isn't an on / off .... all or nothing ... type device .... That being said , when I had Toyo T1r's ( 185/55-15's ) on my RT , they stuck like GLUE and I've had NANNY almost shut the Spyder down completely in some turns do to rear end coming loose...... The Nanny makes getting great Tires useless ....... Mike :thumbup:
While it's probably not quite so cut & dried as all that ^^ makes out, there is definitely a fair degree of reality in there... :rolleyes: :gaah:
It would be sooooo nice to have the capability to 'dial back' the Nanny a bit, or at least dial back some of her fairly cautious safety parameters so that those of us who want to could ryde a bit harder at times; but in this litigious age I can understand why BRP is probably not gonna do that.... :gaah: doesn't mean I wouldn't jump on it if it was available tho :gaah:
And no, 'Sport Mode' is NOT exactly what I had in mind! :lecturef_smilie: Sport Mode only relaxes the traction control restraints on the rear wheel without relaxing any of the steering control or acceleration/throttle restrictions anywhere else - I'd like to see a bit more scope for hard cornering; more freedom to accelerate harder &/or sooner coming out of a corner; less instant response to lifting a front wheel; greater scope for wheel speed differences to allow a little more controlled 'drifting' et al.
Sure, this sort of thing might not be for everyone; but for some, the ability to work themselves a little harder & thereby take a little more advantage of the limits of the platforms capability would be greatly enhanced by allowing some relaxation of the Nanny's restrictions across the board - it obviously can be done, there are enough demonstrations out there, with vids & movie scenes etc showing Spyders doing things that you & I know the Nanny's WE have been saddled with won't let our Spyders even attempt, but somehow, some way, there are Spyders around that DO have more relaxed Nanny restrictions - I'd like to be able to access that/those, or at least some of them! Hey, even it means we'd hafta pass an 'advanced ryding skills' test to gain said access, I reckon there's a market for it... if only BRP would listen & agree/allow it?! :dontknow:
But since they won't even budge on something as obviously 'disappointing' & seemingly stupid to most owners as continuing to run the sub-optimal OE Kenda Tires... :shocked:
Thanks lol! (Now I'm curious as to her "delicate ways.") I'm going to have to disable the anti-slip and do some controlled environment testing. (Like I said, thanks lol!) I've honestly never felt any intervention whatsoever & power has never been noticeably effected. But, maybe it is cutting power a touch so I don't spin the rear tire? ~ I've actually never spun (or tried to spin for that matter) the rear tire, and have little interest in doing so. Nevertheless, I'm truly surprised it has never broken loose, not even accelerating from a stop in a straight line. (Although I've never really hammered on it with intent. And it's the SE model anyways.)
In any event, I'm quite impressed with the on-board "artificial intelligence!"
PS: Coming out of the apex of a turn, my F3-S (se) pulls pretty hard (IMO) without reservation, even in the lower gears with rpm's. (Based on the things I read here, sometimes I think the nanny on my machine isn't online/active at sub 50 mph speeds. ~ Maybe I'm just driving "too delicate" lol.) FWIW: My last bike was a GSXR-1100.
nanny
well i dont have the F3 i have a 09 GS that loves to be played with a couple years ago in Colorado we were carving the curves kinda hard lol i was riding with a goldwing and a triumph having a blast many times i would hear in my headset (we were all running the smh 10 senas ) dude your inner wheel is way up there
its fun to lift it and not get the nanny pissed off
but learn your machine its not there to keep you alive when pushing it past the limit its there to check the oopses
i have had mine check me when hydroplaning and when trying to drift
play with it and learn don't exceed its workings unless you want to be in the situation of ahhh ****
i have seen spyders get away from poor riders and cross the line and hit the other side scary he almost hit the rock wall on the pig trail scared the **** out of him we had to baby him to our destination
Gotta agree with this!
The Billet Aluminum Links actually do make a difference. The OEM links stretch some. More as the stress increases. This dampens the function of the sway bar a bit (making it operate as if it were a bit weaker). It isn't a huge difference. But it is there.
The F3 is far for subtle than the one on the older GS/RS. I've still had it come on hard a few times, but I've found that it is far more polite in the auto braking and throttle retardation than the older models. Definitely carry far more speed into the turns but I have had it hit the brakes hard on me a few times when I was too hot on entry.
Lastly... Whether or not you embrace the nanny or not is very dependent on the road you are on. Some roads you are trying to carry more speed but on others, the nanny kicking in more in the turns can indeed help you go faster... Seems illogical, but it comes down to trusting the bike to do it's thing and keeping the nanny from over reacting.
