NancysToy
Motorbike Professor
Most difficulties with shifting on the SE can be traced to letting off the throttle when shifting, shifting at too low an rpm, or holding the shift button too long. There were some clutch problems that some 2010 SEs had, but those were addressed by a recall/service bulletin. The throttle blipper on the SE basically speed shifts every single time. Rider technique has nothing to do with it.Scotty, one of my concerns is the shifting problems some have had with the SE5. I admit, I did not wring out the demo on the ride. I was getting used to it and took it slow and easy...I did run up to 80 on the Interstate with no problem but did not speed shift through the gears. I will ride both when I go down to the dealer later this week. I note you have a SM5 on order.... Thanks for your input. I value it.
I have ordered another SM for one simple reason...I don't want to be confused. I have been riding for over 50 years...virtually all with a clutch. I own 25 motorcycles, and only five of them have automatic clutches. None has a button shift system. I switch back and forth frequently. It is hard enough to remember the shift patterns, locations of the turn signals, and which side the brake is on (1965 Triumph). I do not wish to add to the confusion by trying to train my thumb to shift, then trying to remember when it is appropriate. Therefore, I stick to the manual versions I am familiar with. It has nothing to do with which version is better, or which system I recommend.
