If you are using or going to use the KewlMetal unit then Jack Goodwin came up with this paper air filter, made for a Briggs & Stratton motor that works perfectly. And the best thing is you can go down to any Lowes and pick one up.
5050
394018S Air Filter Cartridge
272490S Pre-Cleaner
It is a little bit taller than the filter that comes with the KewlMetal unit but it works great. I am running it on my 2012 RT-L and no problems.
Carl
Even though the picture doesn't show it you have about a 10" X 10" square to play with.
About 3.5" of height.
The filter in question couldn't be centered over the Throttle bodies it would need to be offset.
Does that matter? I don't think so, but the filter setups I've seen are centered.
This topic has been covered in various small-engine forums for years, such as Polaris RZR, Yamaha Rhino, Tatum Dune Buggies and on and on. There have been numerous posts with pictures showing that dust and sand particles get past K&N and Briggs filters regularly and cause top end failures in as little as 3,000 miles. And always someone chimes in with 'used them for years'. Yes, but was the engine ever torn down and measured ? K&N filters are for Wal Mart and Auto Zone sales people who don't know better. They are cheap junk marketed heavily. I would do one of two things: 1 - stick with the BRP filters 2 - find a TRUCK filter that might fit, which may be tough in a small space. The only reason K&N filters don't get more of a bad rap is, most street driving is not that demanding.. but one pass through a good dust cloud and you have grit in the throttle bodies and there goes your valves, injectors and rings.
I'm using a Wix #42297 automotive air filter that is also taller on the KewlMetal unit on my RT, Also it cut intake growl down from K&N Filter which is not a bad thing....If you are using or going to use the KewlMetal unit then Jack Goodwin came up with this paper air filter, made for a Briggs & Stratton motor that works perfectly. And the best thing is you can go down to any Lowes and pick one up.
5050
272490S Pre-Cleaner
Carl
When you replace the stock air filter with an aftermarket air filter like the KewlMetal one do you have to do anything like disconnect the battery to reset the computer?
Thanks
JT
Without getting into the fray I just want to say I carry the K&N filters. $38.00 delivered for the RS/GS, etc., and $35.00 delivered for the RT models and all 2013's. It is the filter I use.
Is this the washable filter you sell? Also how do you mount it?
JT, when you make one how about making two?
Bob
