After guidance on Replacing saddle bag latch? 2016 F3 Ltd
johnv50
I finally broke down and bought a manual, all is ok
I need to replace a right-side saddlebag latch. Anyone who has performed this repair that can give me some help??
I should probably buy a shop manual unless there is a free one somewhere on this site.
thanks johnv
You have to remove the saddlebag from the bike. After that is very easy and obvious to replace the latch. Remove the top cover and you'll see the screws that hold the saddlebag to the frame. It is basically hanging on rails and after removing the screws and the plastic pushpin at the bottom it will slide outward and off. There's a disconnect for the taillight.
Thank you for the reply, Jetfixer. I finally broke down and bought a manual. It was a fairly easy job, now the wait on parts. Do you by chance know how to replace the keylock??
Thanks johnv
Thanks johnv
That's a little tricky. At the end of the key barrel furthest from the key, there is a locking tab. Put the key into the barrel and leave it at the unlock position. From the interior (lower) side, you may have a small cover to remove to gain access to this locking tab. You'll need to use a small pick or flat blade screwdriver to push down on the locking tab and then remove the key barrel. When you reverse this procedure to install the key barrel on a new latch handle, make sure that this locking tab "clicks" into place. This photo is from a RT service manual, but the lock barrels are the same.
Thanks again Jetfixer, I was able to swap the old barrel into the new lock.
johnv
As it turns out, you can purchase the latch assembly for about $35. It comes pre-assembled and is a very easy install. Anyone who needs to replace the latch, contact me via a DM and I will guide you through the procedure.
Thanks, Johnv
Thanks, Johnv
I just purchased a 2021 F3 L. The key lock is missing completely! Empty hole! I’m thinking it’s a barrel lock I need? Is this what you are referencing and offering help on here? Hopefully? Appreciate any assistance because I’m SURE going to dealer will cost hundreds of $$$ 🫤🤦‍♀️
I just purchased a 2021 F3 L. The key lock is missing completely! Empty hole! I’m thinking it’sa barrel lock I need? Is this what you are referencing and offering help on here? Hopefully? Appreciate any assistance because I’m SURE going to dealer will cost hundreds of $$$ 🫤🤦‍♀️
* Maybe as you've already seen, this is a thread dating back to late 2022.
* Find on-line a Cam Am parts supplier, there a several, and look for the part/parts you need.
* Order them and install yourself?
