I am thinking about using 3 car ramps to lift my bike for oil changes. 1 BEHIND each wheel then backing up the ramps! Has anyone every done this before? Good idea or bad idea?
That didn't work for me as the ramps kept moving, so I just use an atv lift to get my Spyder up and then place 3 car jacks under it to keep it up.
I assume my owners manual,will show me where to place jacks correctly to lift it up?
Using the rear shock mount as a jacking point has caused some to bend the shock bolt.I had the same problem with the rear wheel ramp spinning out. I just drive up the front wheels onto the two ramps and then place a jack with a small block of wood under the rear shock mount to lift spyder and then set rear wheel on third ramp.
I use 3 auto ramps to do oil changes and also when I want to give it a good cleaning.Never once a problem backing it up on them.I am thinking about using 3 car ramps to lift my bike for oil changes. 1 BEHIND each wheel then backing up the ramps! Has anyone every done this before? Good idea or bad idea?
Bill
If you have the ramps then try the suggestions above. If not...
View attachment 146814 this works best for me. Though I will do oil on the ground...only time I can lie down on the job....:roflblack:
Hi GOZFST,
Re: Using the rear shock mount as a jacking point has caused some to bend the shock bolt
Having read that little piece of advice on here numerous times, I did something a little different.
I lift my front with my floor jack, put two very secure jack stands under the A-arms, one on each side.
Then I made a 'lift helper' for lifting the rear tire. I used a 3" piece of black ABS pipe, cut it to about 6 3/4" long. You will want very clean, 90* cuts at both ends.
I put this onto my floor jack and then lift on the frame just in front of the shock mounting points.
Then I put a large block of wood that I have under the rear tire & set the parking brake.
Works good so far,
Jerry Baumchen
PS) I did not patent the '3" piece of ABS Pipe Lift Helper,' so anyone can use it without fear of impending litigation.
J&S Jacks are the way to go
