HowTo: Adding a FOBO sensor to the Air Shock if you already have an existing Profile
tntnj
This is for those who already have the FOBO app with a Profile.
Buy the FOBO for a 2-wheel bike for $100, the reason being that it will cost $75 for one sensor anyway, so buy 2 and you'll have a spare, or you can sell it for $50.
You will need to find the FOBO Trike set up with the Air shock in it & download it.
Once you add the app with the air shock, RENAME the bike in your profile (you cannot use the same name).
Add a picture in your Profile, you either add theirs or a photo of your bike (you cannot go forward until you do).
(NOTE: you cannot just add the sensor to your current app Profile, it will tell you it belongs to the current name of your Profile).
  1. Now start with the Right front sensor & disconnect it from the front tire, your old app will alarm;
  2. Go to the old PROFILE and hold your finger on the box of the Right front tire, you will see a way to release the sensor - RELEASE it, the Alarm will stop;
  3. Go to your NEW Profile & put your finger on the box you want the sensor to be on & it will say: Install Right - Skip - Proceed down the bottom;
  4. Proceed and connect the sensor and put your phone to the sensor. You should see the tire pressure in the new profile (it may take a few times for the sensor to install it) - Follow what the app says;
  5. Repeat Steps 1,2,3, and 4 for the Left front tire;
  6. Repeat Steps 1,2,3, and 4 for the Rear tire;
  7. Now just press your finger on the lower right box for the Air Shock on the new profile and add the sensor.
YOU ARE DONE - Make sure to Save after you add the Air shock!!!!!
Now you can delete the OLD Profile
THIS OUTLINE ONLY WORKS IF YOU ALREADY HAVE THE APP AND PROFILE SET UP FOR JUST 3 SENSORS
