Accessory Wiring
shooter
Anyone have a copy of a wiring diagram for a 2009 GS/RS. Trying to find power for a XM radio with the 12v/6v hardwire kit.
There is no accessory switch. The RS has both a switched and an unswitched accessory harness. They are tied up front, behind the trunk. Unfortunately, they are likely useless for your application, as they are only 3 amp circuits. Do yourself a couple of favors...buy a shop manual online to get a wiring diagram, and install an aftermarket fuse block to power your accessories.
what a wonderful world
There is no accessory switch. The RS has both a switched and an unswitched accessory harness. They are tied up front, behind the trunk. Unfortunately, they are likely useless for your application, as they are only 3 amp circuits. Do yourself a couple of favors...buy a shop manual online to get a wiring diagram, and install n aftermarket fuse block to power your accessories.
I always know that this world we call spyderlovers always has an answer.
Check out Eastern Beaver, they've got pre wired fuse blocks with a relay to power them. Tap into the battery, hook the relay to the switched power fuse at the fuse box, and you're good to go.
john
