Accessory fuse panel
cougar
Narrowed it down to Centech AP-2, Fuzeblock FZ-1 or Blue Sea. Which one should I get? What are you guys using and why? Not going to use it for heavy loads. GPS, IPOD, Radar, etc.
Cougar
Eastern Beaver PC-8. 6 switched, 2 unswitched. If you take good measurements, they have wiring harness kits too.
john
I like the Eastern Beaver stuff, too. Don't forget to order the diode option to avoid possible CABbus problems from the relay.
The reason I am leaning toward the Fuzeblock is it has the diode protection and the relay all built into one unit.
You can order the Eastern Beaver to suit, complete with diode and relay. All the fuse blocks are quality units. Your choice will depend on your needs, desires, the box capacity and layout, and the size and available space. I didn't need much for my RTS, so I used the Eastern Beaver 3CS, to provide three circuits in a smaller space.
I was thinking of adding the sealed 3GS with 3 switched circuits, what switched wire did you tap into with this?
Received Fuzeblock today. Very high quality. Anyone looking for a fuse block should give this one due consideration.
I used the light green/gray wire that powers the light on the passenger heated grip switch. I did this on both my RTs. BTW, I did not use the sealed version of the 3CS, and I never had any problems, depite a lot of wet weather riding..
