Acceleration
Cavman
Ever wonder why a Top Fuel dragster gets a rebuilt engine after each run?
Stay with this - even if you aren't a 'car nut', this is stunning.
* One Top Fuel dragster outfitted with a 500 cubic-inch replica Dodge (actually Keith Black, etc) Hemi engine makes more horsepower (8,000 HP) than the first 4 rows of cars at NASCAR's Daytona 500.
* Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded PBoeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. Which is typically the output of a small electric arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough force to blow the cylinder heads off the block in pieces or split the block in half !!
* Dragsters reach over 300 MPH +... before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, & NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin 'chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . . quicker than a jet fighter plane . . . quicker than the space shuttle....or snapping your fingers !!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta).
The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
Let's now put this all into perspective:
Imagine this...........
· You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06.
· Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile strip as you pass.
· You have the advantage of a flying start.
· You run the 'Vette hard, on up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH....
· The 'tree' goes green for both of you at that exact moment.
· The dragster departs & starts after you.
· You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that pummels your eardrums & within a mere 3 seconds the dragster effortlessly catches & passes you.
· He beats you to the finish line, a quarter-mile away from where you just passed him.
· Think about it from a standing start, the dragster had spotted you 200 MPH.....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
That, my friends.....is acceleration. :yes:
Well..!!
that is a lot of information and statistics to process...but that is faster than a scalded ape...:yikes:
CAUTION: The scalding of Apes, is an act best left to those professionals among us, who have had specialized training for just such endeavors...
DO NOT try this at home!
The Apes will remember where you live... :shocked:
I'm glad he said accelerates faster than any land vehicle. I have seen this track in use. I was there in the 70's when they were testing various highly classified shuttle mock ups. It's a good thing they have high speed cameras.
I am calling P.E.T.A.
(people eating tasty animals)
Anonymous
Love the newest avatar... It makes you look taller! :roflblack:
I had no idea things were that advanced nowdays. One question, how much fuel is on board at the start? Thanks for posting.
Oldmanzues
Diggers are a lot quicker and faster than they were back in the sixties and seventies when I was driving them. Back then we only saw 3 G's on acceleration and negative 3 G's when we popped the chute. We only topped out at a bit over 200 mph. Of course we had the added thrill of having the engines in front of us (and often on fire). We still used automotive engines, too. Imagine taking a hemi out of a '57 Chrysler on Monday at the junk yard, and having it make 2,500 horsepower by Saturday evening at the drags. No clutch or computer technology back then, either. Drag racing is special in other ways, too. What other motorsport sees the crews rebuild or change the engine in about an hour between rounds? That beats flat rate any day! Drag racing is an awsome motorsport!
BTW, your numbers are outdated. They only run 1000 feet now, but they are quicker and faster.
Read an article about this a couple of years ago (Popular Mechanics, I think). If I remember correctly, it takes around 700hp just to run the supercharger and the clutch plates get so hot they're welded together after the run. Oh, and the pit crew has it all rebuilt in 45 minutes! Pretty darn amazing.
