PW2013STL
*UPDATE* A little Maintenance
Thought I would do a little maintenance before this Saturdays ride. Changing out the oil and filters (both trans and motor), replace the coolant fluid, and the brake fluid as well as new brake pads. Doing a little each night after work and should have it done by Friday night.
This would be a good time to replace my battery, but I want to wait until spring to charge up and install the new battery to get the best life out of it since snow is coming some day soon :shocked:
Update on the progress.
Oil changed - Checked
Oil Filter replaced - Checked
HMC Filter replaced - Checked
Coolant replaced - Checked
Brake pads replaced - Checked
Brake fluid repaced - Checked
Was going to wait on the new battery, but the easy access was to tempting so I pulled the old and cleaned up the bottom of the battery tray and painted it (a little rust) Charged up the new battery and installed it. Kathy helped by pumping the brake pedel and keep telling me she is bored with it, but she did stick with it
The container on the left is new brake fluid and the one in the middle is what came out of my Sypder. The jug on the right is the old coolent. It doesn't look bad, but it is darker then the new.
Tonight I will run it up to operating temp and check fluid levels and finish the assembly so that I am ready for Saturday's ride!
