I always thought it was a model 990 with 998 cc's. Could it be that the 991 model was used in the Aprilia?
SilverFox
they were both used in the Spyder and both were 998CC. I forget what the difference between a 990 and a 991 series.
:roflblack::roflblack::roflblack: 1 what?The difference is 1.
I have the 2013 ST-L. The book says it has a 991 Rotax. However it seems almost all references to this motor mention 998. Did it change in 2014 to 998? Why did they add only 7 cubic centimeters? Were there other differences other than displacement?
Thanks, Billy! :thumbup:
I didn't go into all of the details about the revised powerbands, or how it was achieved...pps:
The 991 moved the power and torque peaks just about 750 or so rpm down the powerband. This was done to accommodate the heavier loads that the RT would be bringing to the table.
The compression ratio went from 10.8:1 in the 990s, to 12.2:1 in the 991s. THIS is why there was a need to switch to a higher octane fuel.
(The 1403 puts a 12:1 squeeze on things...)
Great info, thanks. What octane do you guys use. Do you use the ethanol blend (10%)?
The two Vee-Twin engines are the 990, and 991 series.
BOTH are 998cc displacement!
The 990s were first used in the GS/RS bikes. They made 106 hp., and 77 ft/lbs of torque.
The 991 series was introduced in 2010, as the engine for the new RT model. It was tuned for 100 hp, and 80 ft/lbs of torque.
The 991s got throttle by wire. (The older 990s were throttle by cable) This allowed the RTs to have electronic cruise control as an OEM feature.
In 2013: the 990s were phased out, and the 991 was used across the entire line-up...
... Until the 1330cc 1403 series triple arrived!![]()
