......If the cables are wide enough and you can fit between them there is no reason the Spyder can't fit. My tilt trailer has 1" to spare on each side and I drive our Spyders up on it all the time when ......
That looks pretty flash easysuper, can you give me a little more detail on your trailer please?? Width, length, wheel track, maybe even tilt arrangements & make...?? All that sorta stuff would be handy if you could, but anything you provide would be gratefully accepted. :sour:
As as for it fitting, I park my Spyder in a space that is 20 ft wide but only 68" from the front roller door (full width) to the back wall, so nowhere near 'deep' enough to park nose in (or out...) I reverse it in & then drive forwards to park it across the width of the space - sure, I also tend to store other stuff at each end & overall there's not a heap of room to back & fill, but I rarely hafta shuffle back & forth to get the Spyder to fit so I can shut the door; after all, you only need enough room, anything else is wasted space!! :thumbup: And that counts doubly so when you are planning on towing!!
