murphybrown
First thanks to Pitbull Powersports (Vanessa and Len) for coordinating with Logan Utah dealer, Renegade Powersports..
i had 828 miles on my 3rd set of tires. I was at Renegade at 8:30 am..at 9 told them my trailer tire saga and both service guys said .. That is not right!!! :thumbup: So they take trailer, file a warranty claim with BRP and confirmed my right tire had barely 1/32 tread and left at wear bars. So here is their resolution (we all hope it works).
"remove wheels and inspect all components. Cannot find any damage or signs of impact. All bearings are ok. Measured hub alignment, right side has a discrepancy between the front of the hub and the rear of the hub as measured to the frame. Discrepancy is approx 5mm toed in at the front. Contacted BRP and discussed options for changing alignment. There is no procedure. I was able to loosen the frame mount bolts and "tweak" the frame. Got the discrepancy down to about 1.555 mm. This was as close as I could get it. Installed new tires"
so now I pack up and start working way back to WA. Will keep you posted...until big thanks to
Matt C. tech at Renegade.
