al0vely
2024 Stinger Can-Am (or Trike) Trailer $3,500
Located in Bloomington, IN
Stinger Trailer For Can-Am Spyder RT/F3/Ryker w.spare tire
Specifications:
• Capacity: 1 Can Am Spyder RT/F3/Ryker
• Color: Black
• Weight: 555 lbs.
• Tongue Jack Included
• Stored in Standard upright position : Width: 24″/ Length:90″ / Height: 60″, Unfolded: Width from fender to fender 89″ & Length is 144″ with tongue jack
• Powder Coated for a long lasting finish
• The trailer unfolds to fully extended length.
• Trailer Light Connector: 4-way flat
• Six pins insert and secure the hinged portions of the trailer.
• Fenders and Wheel Stop are standard equipment.
• One rider can safely load a Spyder RT/F3/Ryker and secure the tie-downs.
• Comes with 13 inch tires and the suspension of the Spyder itself provide for a safe smooth ride.
• 3500 lb axle with Sure-Lube® Bearings
• Weight Capacity: 2945 lbs.
• RV, 5th Wheel & Motorhome compatible
• 2 inch Ball Compatible
This trailer sells for $4,400 new.
Specifications:
• Color: Black
• Weight: 555 lbs.
