Badmotorf1nger
I have noticed a metallic vibration around 3-4000RPM,  but only around 15-35mph,  once Im over 40mph its gone.
This doesnt seem to be the intakes vibrating since its sounds like metal not plastic. Seems to be coming from where the driveshaft connect to the tranny on the left side. If I let off the throttle when its happening the sound immediately stops.
I had first checked the header heat shield bolts & the left motor mount, they were tight.
Anyone with similar issue & solution? Anything in that area of the bike that dealer has to assemble & may have not done correctly?
thanks
thanks
