SportsterDoc
6,000 mile report, May 7 to Oct 22, 2020 (5 1/2 months)
Positive
1. The Ryker is a lot of fun, whether instant acceleration from any speed or aggressive cornering.
2. Many design aspects are very practical, from exhaust layout to a bit of storage in the glovebox.
3. The driveshaft/swingarm design is streamlined and very smooth, as a Moto Guzzi V7II
4. Solo seat is actually comfortable, especially compared to stock seat on 2012 Triump Bonneville or 2003 Sportster XLH 883.
5. Engine oil and transmission is easy to drain, if on ramps. Refilling easy, with proper funnel.
6. Cooling system very efficient, even in ambient over 110F.
7. Amazing price point ($9,999 for base 900)
8. Excellent turning radius and at a higher speed than a M/C at same radius
Concerns
A. Changing CVT belt every year for a 1,000 mile per month rider makes maintenance costs a bit high. $220 for belt is OK, but if not DIY, then expensive labor. No provision to monitor belt life / width without removing cover.
B. The Rotax 3 cylinder 900 motor delivers HP well, but cruising at 6,000 to 7,000 RPMs will likely affect life expectancy.
C. Can-Am recommended service interval of 6,000 miles is extremely optimistic and most likely marketing driven. First service at 1,000 miles and every 5,000 miles, thereafter, with pure synthetic oil would likely prolong engine life.
D. No parking / emergency brake. Transmission only equipped with cable operated parking pawl.
E. Large axle nuts may impede roadside assistance for tire repair/replacement.
Negative
a. 33 MPG (likely due to high RPMs) for a 611 pound machine does not provide a long range for a 5.28 gallon fuel tank.
b. Probably due to higher RPMs, ear plugs are essential for rides above ~35 MPH.
c. Stock front shocks do not control the front tires as should be expected. Replacing with 400 mm shocks, with full length springs, is a huge improvement and an extra 2" of ground clearance (base 900). Thank you Chris56 and Tslepebull.
d. The mounting angle of the rear shock provides very harsh reaction on a rough road. The Rally model has a better mono shock, but same angle.
e. Draining the final drive is a bit messy, but refilling through the disc brake slot is not an issue with tube from 75W90 bottle.
f. Changing the oil filter is messy, especially cleaning out old oil. Any oil that spills is difficult to wash away and may drip from the bottom pan for a few days, even after attempting to clean in a coin-op car wash.
g. Starting sequence is annoying: Key popped on, stop run on, press start button, roll throttle forward, press start button AGAIN, while foot on brake.
h. Parking lever rattle annoying.
i. Fuel pump whine slightly annoying, but probably not life expectancy issue.
Positive
Concerns
Negative
