2020 RTL Seat strut barely holds the seat open - ideas?
I found one at McMaster Carr that fit exactly but was like a 40 or 50 LB strut. The seat would jump up almost on its own. Don't remember the part # and this was on a 2012 RTL anyway. I 'm sure you can find a stronger one at McMaster Carr
I did order and receive the 30 LB gas spring from McMaster-Carr P/N 9416K142 for my seat on my STS and it looks like it will work. However, I wanted to see if the 20 LB gas spring P/N 9416K141 will be all that I need, so I have that one on order as well.
Yes, 2020 RTL seat struts are a PIA. Had mine replaced under warranty, now that one has failed. I'm done, I just use a prop to keep life simple. Gee whiz, this could not have been rocket science for BRP.
Ok I have what I think is a suitable work around. Regardless of what Suspa stated in a email to me I did find one that works great. Suspa C16-14870 it is a 30# strut. I also was able to get the bottom and top ends off of the old strut so you can simply just use them if you want to.
I did replace the top link with another one which gave me about a 1/4" more lift at the stud which translated to a good bit of lift at the front of the seat. I like this better as you will have a little more room to fill it with gas.
Here's the best price that I found and as always with them I received them the next day. I'm sure this will vary depending on where you are located. Freight was a little under $8.00 so that also is reasonable.
https://www.mcmaster.com/catalog/127/1374 Part # 9416K14 in 30# You can choose another if you wish but it might break the plastic stud if there's too much pressure on it.
https://www.mcmaster.com/catalog/127/1376 The eyelet end that I used is a 6465K26 it is plastic but works great. You can always use the old one.
Here's on showing the extra length I got with the new eyelet end.
Here's one showing the new strut installed.
Here's one of just the new eyelet
Here's one of the seat lifted
Hey, Thanks so much for this. I tried the helper spring approach. It worked fine on my trunk, but the minute I added a spring to the seat, the spring started hitting the bodywork.
I just ordered the 30 lb strut.
Again, thank you so very much.
