Any suggestions on how I get the right side bag to open? Dealer has the parts on order, but considering the last time they ordered warranty parts took 2 months for the parts to arrive... I wanted to be able to get into the saddlebag now.![]()
What did you wind up doing with your latch?
Mine just broke at the hinge.
Haven't tried to get it open yet, just curious what you did to fix it. Did you have to buy a completely new latch or were you able to just by the plastic lever?
Hi. I had the same problem in the fall. The latch mechanism didn't work, part of it was broken. In October, part only took a few days to get.
Sometimes it only needs adjustment. Found someone who said it isn't greased.
I don't know where you are from, but i took it to the dealer in rutland Vermont. They were great. My local dealer was going to make me drop it off, maybe they would get to it in a few weeks. Didn't care we might have snow, and i don't have a trailer. Rutland was great. Popped it open for me so i could get my clothes out. Ordered part. I came back with bike when part came in, and they did it right then while we'r went to breakfast. Didn't have to leave it.
It's explained how to get into the saddlebags in the owners manual.
For the $50 so bucks it will cost me, I will fix it myself.
How difficult is the fix? and where did you get the latches?
Curious ... just for next time!
I adjusted the cable tension per the kind reply on how to get my saddlebags open.
No issues since.![]()
... I adjusted the cable tension per the kind reply on how to get my saddlebags open.
Could you please reference the adjustment post if you can find it please?
TIA
No problem. Look up under the front of the saddlebag. You will see a cable. Follow it to the adjuster. Turn the adjuster until the latch opens. Then return it to the original position. Call me if you need help. Joe
It's detailed by cptjam in post #2 of this thread Mike - quoted below
Cheers :cheers:
OK thanks. I saw that but I was looking for some type of procedure to get it adjusted to work smoothly ... maybe a tension setting, where to lube ... use a cable lube or not. This seems to be a fix if it doesnt open.
