Update; 1st service done. I don't know if they adjusted the belt, but I think the 'pulsing' noise is now louder, and hearing it at higher speeds too. The Tech. said " All the newer Spyders have that whine" , that doesn't mean that they SHOULD ! I asked about the pulley upgrade, but they could find no information on the computer. I see a number for a new pulley several posts back, so I'll forward that to the Dealer as well.
As for the little 'grunt' noise in 2nd gear, between 2400 and 2600 rpm, they tried to tell me that it's an engine noise because I'm shifting at too low an rpm. Well, when riding alone I'm in Eco mode, and I never max out my shift points on any of my equipment, so I don't believe that story either. At least both issues are logged into my file, for future reference.
Tell the dealer it is in a TSB, better yet take this to them,
10/1/2020 Messagerie BRP - September Product Updates (BRP Community Subscription Update)
https://mail.google.com/mail/u/0?ik...75322878159&simpl=msg-f:1677551775322878159&… 1/2
Lefebvre, Melanie <
[email protected]>
1 message
BRP Community Mailer <
[email protected]> 11 septembre 2020 à 11:27
À :
[email protected]
Hi Mélanie,
Eric_Fauteux (BRP Technical Hub - Global) posted a new article in Can-Am On-Road Product Specialist blog on 11-09-2020 11:26 AM:
Hey guys,
The On-Road season is going very well even if the COVID-19 situation delayed the start off a little. Here is some good information that you may want to be aware of the 3WV family.
MY20 RT Noise reduction Improved Sprocket
My last blog was about a complaint that I'm sure you may receive complaints from RT owners. We are talking about that noise at 70-80km/h (45-50 mph) when cruising.
I've mentioned that our NVH team was working on a new sprocket and I shared the part number. The bad news is that the first batch received from the supplier doesn't meet the engineering requirements. There is still some work to do on it and the goal is to have this new sprocket for the next production planned next January. No worries, they will also be available as for the service part.
Now the good news, I've contacted some dealers that installed the OLD RT belt idler 219800419 and they all confirmed that they get 80% noise reduction which is very acceptable at the customer level. I'd consider that as a temporary solution until we have the new sprocket available. Of course, this will be covered under warranty if it is needed to satisfy a customer irritated. One thing to pay attention to is to
make sure that the idler wheel is perfectly aligned with the belt. As some of you remember, the 2020 RTs were supposed to have a belt idler but it was decided to last minute remove it due to idler bearing reliability. The actual bearing may overheat if there is too much axial play due to bad alignment, keep that in mind.
RT-F3 Loose Mirrors
I lately updated an old TST about mirror vibration on F3 and RT. We do have now a new ball-stud available with revised tolerances and finish. This new ball-stud can be identified with a hole at the as shown below.
SPYDER Loose Mirrors Update - 13746310/1/2020 Messagerie BRP - September Product Updates (BRP Community Subscription Update)
https://mail.google.com/mail/u/0?ik...75322878159&simpl=msg-f:1677551775322878159&… 2/2
Belt Saver on Ryker
The belt saver function is used to prevent the belt from slipping too long under certain conditions and getting damaged.
When the function detects the conditions, the engine torque is modulated to **bleep** the vehicle for the driver to take action.
The worst conditions are quite good when the vehicle starts (worse on hills) and when the vehicle is leaned against something, like a block of cement.
Above a certain speed (5km/h/ 3mph), the function is deactivated, even if you release the accelerator.
@Marc-Antoine did a good video showing the condition.
(view in My Videos)
Scotch Grip.... again
I know this will probably get the attention of my good friend @RPM_Matt with that %$#@!!! ScotchGrip ... Last week we got an interesting case with an idling issue that I wanted to share what we found. @RobZastrow and @joshf from CC POWERSPORTS KY did a pretty good job on that one. The unit was shutting down randomly with no fault codes on a low miles MY20 RT. After some investigation, they found an excessive amount of scotch grip on the main ground wire. Simply clean out the %$#@!!! ScotchGrip and all good after that.
Cheers!
