KX5062
Still riding. How was the install? I'm mechanically challenged, so I hope it was easy!! Are all the wires long enough to accommodate the riser? Thanks, and glad you like them.
steve
The wires are plenty long enough, but they are shortened by way of zip ties. This is the only tricky part, because you have to snip those hidden zip ties without damaging the wires.
The zip ties can be accessed by carefully popping off the speaker cover, which is only held on by plastic tabs on the corners on the underside. Then you have a reach and limited access to get to the zip ties. It's not difficult, but it can be tricky.
