Thanks for the reply we did have it in the mechanic says nope shifts fine lol well she should know she has ridden a lot more spyder than he has. I drove it home from her first oil change and I noticed it right awayI have an ‘18 RT and it shifts very easily. You definitely have a problem, I’d call/bring it back to the dealer.
‘Good luck.
My wife’s 2018 RT takes a abnormal amount of pressure on the paddle to make it shift. Her 2015 flicked thru the gears with very little effort.. Any ideas?
Thanks pale spyder it well be going in ASAP I see it’s not the only one. Thanks for the postYep ... I have some ideas. Just got my 2018 RTL back from the dealer - guess what was wrong. Shifting - in particular downshifting went from hard to accomplish to just won't happen. The paddle / lever was defective and replaced under warranty. I can even get you the part number ... once I get back home.
Well doTell your dealer to refer to warranty bulletin 2018-5 for this problem.
Thanks everyone for the advice. A shout out to billy bovine for the BRP case number we called the dealer and since I had a BRP reference they ordered the cluster before we took it in they installed it right away. We picked it up last night after work. My wife was super happy shifts right and the joy stick and the blinker cancel all works easily. They also got the buds 2 to work and installed the newest update. I let them know I had read here that they had to use the cable and one on the USB port then it worked. Thanks again everyone we well be headed down to council bluffs Iowa for the spyder fest hope to see some of you there. Let’s RIDE
I'm getting the whole left handlebar control replaced next week because of the same problem.
In my case, contrary to the service bulletin from BRP about downshifting, it is the up shift that is giving me problem.
In about 1 out of every 3-4 up shift, I have to hit (and hold) the paddle more than once for the shift to happen.
You gotta have some patience, I did and my situation was handled swiftly.
Did you ever get your whole left handlebar control replaced? Thanks.
My new 2018 RTL. Dealer looked at it (In about 1 out of every 3-4 up shift, I have to hit (and hold) the paddle more than once for the shift to happen) and dealer agreed that it takes two or three times to hit the paddle to make things happen and told me "We have a case openwith BRP presently and we're waiting to hear back from them on the issues!" Have not heard anything for 7 days so far!!!! How long does BRP take to answer a dealer? Winter salt is coming soon and would like to ride.:banghead:
Any advise?
Shouldn't be any "case open "stuff.The issue is covered by warranty bulletin 2018-5.A known problem but still took 2 weeks to get the parts for mine.
