Spyder Insyder
XM Radio
Well, I finally installed an XM radio (Onyx Plus) on my 2018 RTL this weekend. Overall I am quite pleased with the results. Installation was straight-forward and required removing some bodywork on the right side. The unit came with an aux. audio cable with male 1/8" stereo plugs on both ends. Since the audio input cable on the Spyder also comes with a male plug, this required a double female barrel connecter to make the connection. Power was sourced from a 5 amp accessory fuse in the right side fuse box. The receiver was located to the glove box, and a 3/8" hole was drilled into the sidewall to allow the cables to enter. Initially the audio was a little low, but the receiver has a menu setting that allows you to increase the drive. With the audio output level set to max, there is plenty of volume, even at highway speeds.
The only downside is, you have to open the glove box lid at a stop to change channels. However, that's probably the safest way to do it anyway.
I also am thinking of installing an XM receiver on my 2018 RTL. I have done that in the past with previously owned Gold Wings. The only problem I had was the frequency I chose for the XM modulator would sometimes be over powered by a local FM station on the same frequency, as we were traveling.
Installation on the RTL looks to be fairly straight forward, with the hardest part being removal of body work for running power and antenna cables. It seems the obvious location for the receiver would be the glove box. I'm not quite sure about the antenna. Probably the top of the rear trunk, although the surface area seams to be at the wrong angle for a 90 degree facing to the satellite. An unused 5 amp accessory fuse is provided in the fuse box.
I would be very interested in hearing the details of your installation. Please feel free to PM me if you like.
