2016 RT Owners manual
LLSailor
Has a section describing a 600 mile break in period. Then it says, "After the break-in period, your vehicle should be inspected as per the MAINTENANCE SCHEDULE subsection." The first maintenance in the schedule is at 3000 miles. Should it be inspected at 600 miles, or wait until you get to 3000?
:agree:
For the first 600 miles: vary your engine rpm levels, try to avoid much W.O.T. operation, and go a bit easy on the brakes...
After that: it's PARTY TIME!! :yes::D
They have you covered above. Break-in and break-in servicing are two separate line items.
Break-in refers to the first 600 miles of operation. Give the brakes and tires about 300 miles before doing burn outs or hard quick stops. Vary the rpms a bit.
Break-in service is recommended now at 3000 miles. First oil change, filter, and mechanical check over.
Being conservative, I do not drive it like I stole it--but you will be hearing that also. Its your money, its your :f_spider:.
