2014's with oil leaks
Hi everyone,
There seems to be some confusion surrounding this bulletin. Here is the corrected information:
The bulletin mentioned in this thread is deprecated; it was temporary and has been replaced by a newer one that your dealer will be able to compare your VIN against. The dealers who will service affected vehicles (a very small number) should already have the parts required to perform the update shipped to them. Also, note that all vehicles produced after this bulletin was released already have the update applied to them.
Hope this helps clear things up.
If the original list of VIN numbers are not valid, then that still leaves some of us who purchased early built machines, before the OIL LEAK was even mentioned, without any idea as to whether ours have a potential LEAk. The dealer may know, or may not have paid any attention to the updated info. Often we hear about dealers who are totally in the dark about a given bulletin.
Steve, can't you issue an updated list for us to compare and then get with our dealers as we see the need? If not, I can truck off to the dealer in inquire.
I'd just feel more comfortable knowing.
i think
i think if the dealer we bought our bikes off of is not a heavy BRP dealer as far as spyders, that they don't tune into what is going on. my dealer is not a big spyder sales dealer and he had no clue as far as the heat fix or now the ecm update, both times i brought the paper work that i found on here
Hi everyone,
My dealer will be fixing a leak on my new 2014 RT Limited next week. Also, the dealer will be replacing both front lower panels. They are both loose, and the right side panel flew off into the road and got run over by autos that were behind me. Neither fit well at all. New ones on the way. This issue has caused a little consternation at the dealer. None of his other 2014's have this issue.
whats your build and vin if u don't mind sharing? Mine was Jan 7, VIN #570 and they said it was not in the recall or had leaks? Is the leak in the clutch set screw area?
Hi everyone,
Steve,
Just got off the phone with my service manager and mine definitely has the oil leak where the clutch screw is. Just a heads up as it looks like those that were supposedly fixed were not fixed at the factory, well at least mine was not! BRP is sending the set screw kit with Loctite to get this fixed. Lets hope this is the only issue with the 14's. :)
BRP sent the replacement parts in 3 different shipments. I mean come on, all that is required is Loctite, a small screw, and one other item. Really BRP. Dealer couldn't give me a definite date although they said it was shipped Wed express overnight! Probably wont get here till next week due to weather, customs, ect!
Good new is, I finally spoke to the tech working on my bike. He is going to double and triple check everything on the bike before its completed.
​My dealer called yesterday to say my RTS is now "on the list" to have the leak fixed. I've not noticed any leak and the dealer initially said that my Spyder wasn't affected. The service manager said that I'd have to leave it overnight so they can be certain that the sealant set up properly.
Help.......
As many of you know there are some of the early build 2014's with the clutch set screw leak. The service bulletin is out and most dealers do not have it yet. (at least the two in my area didn't). Anyway, the part needed is Loctite #7649 (primer, found locally). Well, of course the dealers did not have it and had to order it. No one had it locally either.
Just a heads up for those getting this repair. Make sure your dealer is using this exact primer. Mine is still sitting at the dealer for a week now. Hopefully they will get the Loctite Tuesday. Fingers crossed.
http://www.spydertechnician.com/dlfiles/2014 RT SE6 Clutch Cover Oil Leak - Set Screw.pdf
Hello fellowSpyder Lovers. We are looking for other Spyder owners who might have had a problem with the porous metal oil leak. We had about 4000 miles on it before it started. It has been at our dealer for almost 1 month...Any info on how yours was handled would be appreciated, Thanks in advance
My 2014 with only 100 miles has leaked badly vin#5145. The dealer tells me that 2 set screws need replacing and sealed. The one screw seems to now be ok after sealing, the clutch housing screw still leaks and the are asking BRP for a new clutch housing. New machine that should have been corrected at the factory or dealer before delivery. I have no idea as to when I will get my Spyder back - what a tease!
palover
palover
Close to yours - my vin #5333 no oil leaking problem in 1400 miles.
palover
On the birght side; the source has been found, and a fix is in the works! :thumbup:
I'm rel sorry to hear that you're having to endure this...
...But the bike (and the wait!), will be worth it! nojoke
2 oil leaks in my 2014 Spyder LT
Hi everyone,
I only had it 3 days and 100 miles. The dealer tells me he has found 2 oil leaks and he needs a new clutch housing. Afraid to take the Spyder on any trips for fear of being stranded, totally unacceptable, when BRP knew about the leaks early this year, why were the defective machines allowed to be delivered to dealers? My new Spyder was only 3 days old with 100 miles. If I pursue obtaining a new replacement there is no guarantee that it will not leak. I'm talking to my attorney after Labor day in an attempt to obtain a refund from BRP. I knowingly was sold a defective product.
Ed Tirk
VIN# 005145
[email protected]
Porous Metal Oil Leak
CFPS and WCPS dealers in central Florida have replaced 5-6 1330cc motors because of oil leaks through the motor case. I believe namknight (SL name) may be the most recent. Might want to give Central Florida Power Sports or West Coast Power Sports (in FL also) a call. Also recommend you contact BRP and open a case file.
OIL LEAK ISSUE
:gaah:.....Sorry to hear of all your problems ........so this is just a point of reference 2014 RT,, 5300 + miles VIN # 006475 no leaks , so far :pray: :pray: :pray: Mikeguyver :thumbup:
Production was actually halted early on to fix defects caught on some 2014's at the factory.
There were some complaints then that production was being held up. Most were glad this happened as it showed that BRP was trying to put out a good product.
The 2014's appear to be winners with very few exceptions.
Not every 2014 is going to be perfect, but it seems to be much better compared to 2013.
How so? Most 2013 owners did not experience the heat related issues seen on this site. Probably the same is true for the 2014 owners as well. Too bad there isn't a way to know the true numbers for affected machines from both model years.
Well... There were ball-joints, shocks, and heim links too... :D
Bob - the 2014 has had other warts as well, including the whole key issue. I'm not looking for a comparison between the two years. I was just saying that it would be nice to know what percentage of units from both years actually suffered the issues that have been seen on this forum. I'll bet that the actual numbers are pretty small. If known, then would be owners might be able to feel more confident about their purchase knowing that these problems truly are not wide spread.
I do not have actual statistics. But then, everybody seems to interpret them to go with their take on the subject.
My comment comparing 2013 vs. 2014 was based on the shear number of complaints and issues talked about here on SL. I am a regular and read pretty much everything on the site. Those that do the same will most likely agree that there have been fewer overall complaints for the 2014 year compared to the 2013 model year.
I am also very happy that there are many 2013 owners that challenge the fact about the "bad model year" argument. That also verifies what I have said many times concerning a 2013. You either get a good one or a bad one.
