SAPD911
As many of you know there are some of the early build 2014's with the clutch set screw leak. The service bulletin is out and most dealers do not have it yet. (at least the two in my area didn't). Anyway, the part needed is Loctite #7649 (primer, found locally). Well, of course the dealers did not have it and had to order it. No one had it locally either.
Just a heads up for those getting this repair. Make sure your dealer is using this exact primer. Mine is still sitting at the dealer for a week now. Hopefully they will get the Loctite Tuesday. Fingers crossed.
http://www.spydertechnician.com/dlfiles/2014 RT SE6 Clutch Cover Oil Leak - Set Screw.pdf
