2014 TRAILER WIRING COLORS
BLUEKNIGHT911
Sadly Passed Oct 2024 - RIP
:banghead:.......I would appreciate any assistance from anyone who KNOWS ( not guesses ) the colors of the wires that come from the fuse box and end at the LARGE connector under the panel, under the seat. This is a male end with 7 wires going in ( much more going out ).......I'm hard wiring a 5 to 4 convertor to use on a Trailer with all LED's . I understand WHY there are 7 wires going in and I know what they are all for .......I just need to know which color does which function.........( ie white = brake lite etc. .....I think this correct ? ) ..................Thanks very much for any help on this .....PLEASE NO GUESS 'ING........I only want to solder this once :roflblack: :roflblack: :roflblack: :thumbup::thumbup::thumbup:......Mikeguyver
WELLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
:gaah:....Thanks Steve ................I'm not UN-familiar with wiring diagrams ...............but the above appears to only have 5 wires coming in to the connector.....Mine has 7.......I know what those seven wires finally end up achieving.......as a whole .......I would like to know which colors are lft. and rt trn sig wires .........stop lite.......park/running lite....... brake actuator for 622 trl.,.........reverse/back-up lite..........grnd wire ............The dia. gets kind of un-readable when you blow it up and I think part of the front is missing...............................but thanks ....Mikeguyver...:thumbup:
Left Tail - OG
Left Turn - GY/PK
Left Brake - WH
Ground - BK
Right Tail - OG
Right Turn - BN/YE
Right Brake - WH
These wires are for the bike.
622 trailer does not have backup lights, but I believe the bike backup lights are PK/BG.
I believe the 622 no longer has individual turn lights, it uses the brake lights.
I guess that's why the trailer harness only has 4 wires now.
I do not have the wiring diagram for the 622 trailer.
That is all I got, I hope it was helpful.
THIS WORKS FOR ME ....................YEA
Left Tail - OG
Left Turn - GY/PK
Left Brake - WH
Ground - BK
Right Tail - OG
Right Turn - BN/YE
Right Brake - WH
:clap::clap::clap:....Thanks Steve, from the looks of this BRP sort of has a " CONVERTOR " type plug there also........7 in ...6 out to trailer ......and everything works as designed .....Your picture is of the MALE side of the plug but that's fine .....I can figure out the female end ...........PS on the FEMALE side there is an ORG w / purple ? stripe that is blank on the male side. ......It is Hot though ....because I tested it............Thanks again....Mikeguyver :thumbup: :thumbup: :thumbup:
