2014 ST Limited - Belt Tension Question
MurrayBrown
I think, but am not certain, that the drive belt on my 2014 ST Limited m-i-g-h-t be a little slack. Rationale? At certain speeds ... around 103 - 109 km/h (64 - 67 mph) the handle bars shake ever so slightly. Not a major shake; they just aren't as "smooth" as at lower and/or higher speeds. The only other way to describe the "shaking" is it is similar to an unbalanced tire. The tires are balanced, and the ST runs as smooth as silk at all other speeds.
Unlike other Spyder models, there is no belt idler wheel on my ST. I have looked at the BRP Maintenance Manual that I have and the way to measure belt tension is with some super-fancy electronic device that calculates the tension (please see the images below).
Does anyone know of any other way to measure belt tension? I'm used to motorcycles where you measured the "play" such as +/- 1/4-inch tolerance, etc. and adjusted the belt tension nut accordingly.
Example:
Drive Belt Deflection (with 45 N, 4.6 kgf, 10 lb force) Standard: 1.5 ∼ 4.0 mm (0.059 ∼ 0.16 in.)
