2014 RTS Oil Leak
Questions
I just took my 2014 RTS to the shop for an oil leak. It has 3966 miles and they told me the oil leak is coming from a screw in the bottom of the motor. They said they called brp and were advised to blue locktite the screw and it should be fine. So far they test drove it twice with no oil leaks which is great news but i'm still waiting for the bike as they wanted to take it for one more ride.
Is this a 14 problem or has anyone had this?
stan
Just had it done last month on 2015 RTS
stan
Great bulletin share from Hayfield!! That's what we suspected after taking off the lower right plastic belly pan and seeing the oil drip hanging from that clutch cover/pressure sensor area. It looked like the set screw was moist with oil, but weren't quite sure. Local dealer cleaned it up and used the primer and oil resistant loctite as per the bulletin, and no more drips on the floor. Made a copy of the bulletin to take in to the dealer in case they hadn't seen it yet. Had about the same mileage, and noticed it during the 3,000 mile service.
That was supposedly an issue that affected only the very early production models of the 2014 s and was then supposed to have been corrected at the factory..
2015 RTS - Had Loctite Primer AND Blue 243 Oil resistant fix in May this year
It's on the sticker on my swing arm. Just thought that leaking trans screw was an early production issue that had long since been corrected.
It probably was more prevalent but just had our 2015 model fixed as per the bulletin. It would seep a 2" spot on the floor after a 200 mile run.
Fixed by the local dealer under warranty at 3800 miles and now at 8900 miles with no further leaks. Looked dry on the right side clutch cover bottom last night when I did the latest oil change.:thumbup:
Such a leak on a '15 would indicate that the engine manufacturer had a production line burp or in this case a puke -- a definite quality control problem.
I've also heard of a couple of folks who got new engines because of oil leaking right through the block . . . apparently a few bad castings slipped through.
oil leak possibly back.
Well I got my bike back and took it for a 40 mile ride and everything was ok. I then took it on a 70 mile ride today and I had a small red colored leak under the right side area of the bike. What the heck is that now?
stan
My '14 RTS se6 had the leaking screw. At SF '14, the BRP techs fixed it. The sealant they used required 24 hrs. to "set up". No leak problems in the ensuing 8000 miles.
A red leak would be antifreeze unless the dealer used red die in your oil. My dealer used green die in my oil.
By chance does your leak look like this under the bike??
My 14 RTS production date of May was taken in and had and oil leak through the case. Waiting to see what all happens.
Yes this is exactly what mine looks like. I will be bringing it back to the dealer again.
stan
