Coolvirgo54
Recently purchased a 2014 RT-L with low K's and in brilliant condition. Rode it home on Forrest highway 130km and it sat true and straight all the way. I was thinking I had misjudged the Kendas. (Fitted car tyres to our RT-S SE5 and it was a different bike). First ride 2-up with the guys on our back roads and it was all over the place. It also pulled to the right under hard braking initially and wobbled a bit from left to right which was really unnerving. Checked rotors and brake pads and toe-in. Toe-in was between between 0-1mm and pads were fine but noticed very light and fine scoring on both sides of all 3 rotors with the BRP pads. Rotors should be shiny on any vehicle. I lightly refinished the front rotors with coarse wet and dry on the lathe and put it back together and rode it. Better but still pulled to right a little and was unstable under heavy braking. Fitted new aftermarket pads and braked in a straight line but still unstable. Fitted Kumho 175/50 R15 (rear was already a car tyre)and immediately everything stabilised almost completely, sat on the road and cornered at speed with dead stable line on uneven paved surface. Rear of bike now did not feel good under heavy brakes but front was great. Replaced rear pads with same make as front and everything is now perfect and rotors are shining up. Braking effort is also much less. Looking at the BRP pads I noticed they were very hard with a lot of metal impregnation from manufacture. This probably explains the light radial scoring. So there were three things causing the braking instability. 1. The scoring of the rotors caused by the original pads being way too hard and abrasive. 2. The Kenda front tyres. 3. Uneven braking distribution between front and rear after fitting aftermarket front pads, until same sintered compound rear pads were fitted. I know from forums and posts on various pages quite a lot of people have experienced similar braking instability and replaced (and/or) rotors, pads, calipers and steering alignment chasing the problem. I wonder how many of those were simply pad compound and Kenda's. I also wonder if BRP used different pad manufacturers and there was a bad batch.
		 hyea:
hyea:
