2014 RT-S SE6 Parking Brake Adjustment
JayBros
Well-known member
The parking brake, Brembo, on my 2014 RT-S, SE6 no longer firmly holds my Spyder, particularly when parked on grade heading uphill; it rolls backward. There is a video in SL that shows how to adjust the brake but it is for a Spyder with a manual vice electric parking break. It shows having to remove the brake actuator arm, making an adjustment, replacing the arm and fine tuning it by adjusting the barrel adjuster on the brake cable.
I took a little slack out of the cable with barrel adjuster but the brake is still not tight enough when set to prevent the Spyder from rolling backward down my driveway grade. I don't want to over adjust the brake so that it drags when released but I would like to avoid the time and expense of the 180 mile round trip to the dealer for what seems to be a very minor maintenance job. Am I approaching the problem correctly? Do not yet have service manual. Any assistance greatly appreciated. Thanks much.
same here,,, on slight inclines my Spydy does the same. was almost really bad when i was lined up for a bike ride & almost rolled into another bike, i carry a small wheel chock with me & just put behind under 1 wheel just to be safe now.
Parking brake failure is not an uncommon ailment for Spyders in general.. You may want to make a dealer visit before it quits all together
After the dealer try adjusting my parking brake twice, last time they tightened the adjuster so much the rear brake was overheating, I had to back it off before taking it back to the dealer again, they then changed the parking brake actuator, that fixed the problem. I learned from this forum that some of the 2014's had a weak actuator. Also it was covered under warranty.
After the dealer try adjusting my parking break they changed the parking brake actuator, fixed the problem. I learned from this forum that some of the 2014's had a weak actuator.
Thank you. That's an arrow for my quiver. I believe I have it adjusted now as best I can get it. Might also spray some brake cleaner in that part of the caliper.
Let's see..!!
if you run out off threads on the cable adjuster it is time to move the pivot arm. Set the cable adjuster all the way back loosen the arm bolt pull the arm out and set it back a knotch. Reinstall the arm tighten the bolt and readjust the cable. As the brakes wear you need to keep adjusting but hard to tell on the electric till it rolls off. Manuals have a clicker system...remember you did this when the pads are replaced cause you will have to set it back again. Easy enough to do you just need some play on the arm when reset. Push it forward and you can feel when it makes contact...:thumbup:
I agree, had the same problem on my 2014 and a new brake motor actuator was required, under warranty. Problem solved
Cruzr Joe
After the dealer tech saw today that I had correctly adjusted the parking brake to the max and it still wouldn't hold he declared the actuator motor defective and it will be replaced under warranty. Part ordered but I still have use of the trike. FWIW, the dealership has seen several defective motors.
Redneck Diva: suggest you visit your dealer to get your problem solved.
The actuator motor was defective on my 2015 RT-S. Dealer replaced it under warranty. Mine started rolling while parked on a steep driveway when someone touched it. [emoji53]
My 2014 RT would roll if parked on an incline and a small incline at that. Took it to the dealer. They reported the actuator moves into position, then backs off enough to let the bike roll. They said they've contacted BRP. Thanks for the info. I'll pass the remarks to my dealership and see what they come up with. I can only park on level ground.
Rolling with Parking break on.
I have a 2014 ST SE5 and have replaced the break pads and the bike still does not hold on a hill. Some people have stated that the break actuator was covered under warranty. Was this the normal 2 year warranty or some sort of quiet recall. My bike is out of warranty, and I have the parking break adjusted once already by the dealer when it was under warranty and that fix lasted for a year.
I have tried to move the break arm but it does not want to give either way by hand and I don't want to try to force it. Any idea's
I too had the parking brake motor replaced on my 2015 RT. Mine would roll back on my steep driveway. I actually watched the parking brake at the rear of the bike while my wife worked the switch. I could see the parking brake lever more forward to lock the brake, and then it would back off slightly.
I sent a video of what was occurring to the service manager at Caswell Cycle and he emailed me back and said it was a known problem and ordered the parking brake motor. Sending him the video saved me a 130 mile round trip ride for diagnosis.
Gunner
