2013 Spyder RS - ST Handlebar Swap
Thank You!!. Is BRP the only ones that sell the ST Bars? What is the difference between the Stock and the ST Bars. Do bring them closer to you, like the risers?
The ST bars are stock handlebars from a Spyder ST. So Your Can-Am dealer will be the only place you'll be able to get them. In an above post you
l see a parts list that you will need to order for the install. I think all the parts total out to right around $200. The ST bars will bring the handlebar position up and back to give you a more upright and comfortable riding position. The really cool thing is, since they are stock Can-Am parts your Spyder still keeps the stock look.
Just completed the exchange with no problems. I found you don't have to remove the rubber boot on the ignition switch. Just unbolt it. I agree, the hardest thing was replacing the left hand plastic cover underneath. You also need to order additional Allen screws to hold the new plastic covers on. Great job explaining the replacement process.
Good morning to you
Do you know if ST bars will fit on a 2012 RSS SE5??? I'd rather go this route than risers...
Thanks in advance,
roller
This swap will require a moderate mechanical ability. If your handy and have worked on motorcycles and/or cars you can handle this mod. The follow are the tools that you will need.
1. 10mm socket
2. 8mm socket
3. 7mm allen wrench
4. 5mm allen wrench
5. 3mm allen wrench
6. T-27 torx bit
7. straight screwdriver
First use the T-27 torx bit to remove the upper plastic body panel that covers the "backbone" and the side panel (where your knees would be).
attachment.php
Great write up, thanks. I'm getting ready to do this swap... one quick question - why do we need to remove the body panels? Also, is it three total panels to be removed?
Much appreciated,
Bodgerist
CAM-AM PARTS
.... Wrong----there are lots of places to get genuine Can-Am parts other than the BRP dealer for lots less money ......PROCALIBER.COM --- CHEAPCYCLEPARTS.COM.........Mike :bbq:
2013 RS to ST handle bar swap
Much appreciated,
Bodgerist
Because the rule is you MUST remove at least three body panels to do ANYTHING other than dismounting from the seat and refueling!!!!
:yikes::yikes::yikes::joke::lecturef_smilie::lecturef_smilie::lecturef_smilie:
So Much Better!
Thanks hchays for the write up! it was super easy to follow and execute. I did not, however need to disassemble the ignition to remove it from the original bars. And a big thanks to alwaysontwowheels for selling me his black ST handlebars to put onto my 2013 matte orange and black RSS. Couldnt have done it otherwise.
Finally swapped RS for ST Handlebars - thanks for the excellent writeup!
So, a year after buying the parts I finally made the handlebar swap. Thanks again for this excellent instruction set. A few comments:
- DO IT! If you have an RS, swap out the handlebars! It doesn't take away from cornering at all, and it causes you to sit in a much more comfortable, neutral position. Motored around for over an hour with the ST bars and felt nothing in my lower back. Zero fatigue, Zero discomfort.
- I agree with the earlier observation about the ignition pod. Once you remove the two 10mm bolts and remove the bar with threaded holes, you can lift the whole pod upward toward the direction of the ignition key and just rotate the top boss 1/6 turn counter-clockwise to unlock and remove it. Then the whole pod comes out.
- I recommend buying new bolts for the handlebars and the handle tube clamps - the manual recommends to do so, and they come with loc-tite pre-applied.
- The left hand side ST handlbar plastic cover was definitely a bit of a challenge to install. I finally got it by installing first the lower and back sides, then forcing the forward half around. The plastic is really bendy.
- Routing of the wires on the left hand side goes forward of the hollow. It will all tuck into the plastic cover, except the clutch cable which has it's own recess in the plastic.
- Handle tube clamps get 89 in-lbs of torque to install. Handlebar bolts get 28 foot-lbs. (P604 of the manual)
- You'll need a total of 8 of the small bolts that hold the plastic covers on - you'll only have 4 from the RS.
- My ST handlebar was used and didn't have the green metal cable retainer clips. I reused the ones from the RS, but found there was a clash when installing the left plastic cover, so i removed the clip and just tucked the cables in.
- This took me a total of about 4 hours, but I work extremely slowly.
- Did I mention to make the swap? Do it!
Best of luck,
Bodgerist
Great write up and install experience recommendations. For all that have done this how tall are you guys? Is the ST worth doing if you are say up to 5'-10" and above that should be the RT?
rs-st handlebar swap
if you have an rs spyder, and the handle bars are just to low and unconfortable. then this swap is for you. i swapped out the bars on a sat. afternoon. the parts for an 2013 SE5 are 709400983, 709400987, 709400989. the st parts bolt right on with no trouble..
have nice ride
2012 RS SM5
I know someone posted on this once, but they also said 2013-14 wasn’t probably interchangeable, but what about the 2013 RSS/ST to a 2012 RS sm5 handlebar swap? It would be nice to use the center bolts on the newer year bars for a gps mount etc, but also for the comfort.
Thank you so much for sharing this procedure. I was stumped by how to get the ignition switch out, but now I think that I can get it . Al in Wisconsin
Ignition switch spring
Hi, While getting the ignition switch off of my oem handlebars, I had to take the ignition switch partially apart (st onto my rs) . In doing so, a little spring fell out (3/4" or so in length, similar to the spring in a ballpoint pen) .It has to do with the key turning in the key cylinder.
The problem is that now I can't figure out how to get the spring back in.
I have checked my service manual, but it doesn't even show the spring.
If you can guide me on getting the spring in correctly, it would be greatly appreciated.
Thank you very much. Al Schroeder
Hi,
I'm doing the swap. Where does the little spring go? My spring fell out when I took the ignition switch apart.
Thank you for any help that you can give.
Al Schroeder
