oldguyinTX
I have now put a little over 200 miles on my RTL since having the recall work done. I do like the way the scoops look. I considered painting the flat black part of the scoops Pearl White, but decided to leave them as is. The Spyder is noticeably louder, due to the removal of some panels under the Tupperware being removed, but not at all annoying. Now, as to the heat problems. I have ridden in 80 degree stop & go traffic, 75 degrees & rainy, today, 82 degrees on back roads - never got out of second gear - and finished off with an 80 MPH highway run. I stopped several times, just to take my right glove off and feel for heat around the front of the seat and right side panels, and sniff for gas fumes. All areas were cool to the touch which is a night & day difference from when the heat would roast my chestnuts. Also, no gas fumes. I have filled up a few times, and there was no boiling of gasoline in the tank either. I have to say that I am thrilled with the results of the recall. This is now a totally different machine from the one I bought and suffered with for two years. I really do think that BRP got this right. Any of you out there that have not had the recall work done, I would advise you to get it done as soon as possible. I think that you will be very pleased with the result.:thumbup::thumbup:
