2013 RT LTD ACS System
racedogs
Do all 2013 RT Ltd's have the ACS system installed? I purchased mine used and it does have the switch on the dash. When pushed it displays the bar on the left side of the display and says "MANUAL" vertically in the bar. I have to add air to the system every time I ride by the Schrader under the seat. It will go from 80lbs to less then 40lbs in the span of 24 hours. Something is wrong.:banghead:
Yes, all 2013 RT Limiteds have the automatic adjustable rear suspension. Only the base model did not have it, and those did not have the switch on the dash either. Even if the air bag looses some air overnight (it should not) the onboard compressor should refill it shortly after starting the engine.
I have never heard a pump or air valve sound since I have owned it. Is there a place I can look to actually see the compressor or height adjuster sensor to confirm it really is on mine?
I had the same problem
You may need a new compressor. Mine did the same thing and my dealer found that the compressor was bad, it was replaced under warranty.
Switches to manual
I had to replace position sensor switch. My fault not machines! One of those learning curve things. Anyway if the auto system can't adjust after a few tries it will switch to manual. The bar on the left that gives ride firmness displays "MANUAL"
Dropped the bike off at the dealer on Tuesday. They called today and said that they had a compressor on order for it and that it should be ready Friday.:thumbup:
