Hi jetmech,Does BRP have enough parts to all the RTs affected?
Hi daviszoo1,Also would there be any consideration on what we had done on our part to help with the heat issue; (wrap the pipes & adding insulation). Thanks in advance for your reply.
Hi daviszoo1,
Yes. Please keep all receipts related to any work performed on your Spyder RT done with the intent of addressing high levels of heat in the engine compartment. When you visit your dealer to have the recall work performed, your dealer will notify us and be made aware of the procedure to follow, if any, to have this addressed. Note that only modifications performed with the specific intent of addressing high levels of heat in the engine compartment will be considered for compensation.
:agree: Post them in hers... Somebody will find a good use for them! :thumbup:
Same here. The full instructions will be in the repair kits. A copy will get posted here soon enough. I will if we are the first to see them. Appointment scheduled for next week, parts are due in by June 2.
I am going to go out on a limb here about the scoops as I have had my Spyder apart many times and looked at this area for a DIY.
The stock openings these vents feed is paneled off inside to the full internal engine area (they seem to be there to let heat from the radiator go up and out when your not moving).
My bet is just adding the scoops is not all they are doing. I think there is also going to be panel mods inside to direct the air from these scoops the back of the engine area.
Steve, care to elaborate? We are curious
Bob
Hi jetmech,
Yes, as mentioned earlier the required parts are already available and will be shipping to dealers upon request.
Examples:
Wrapping pipes
cat-bypass
heat coating
virtika scoops
additional heat shielding
Does this include labor?
It's important to note that the recall fix was announced today; both to the dealer network as well to owners here on SpyderLovers and other social media. Information travels fast on the web and with dealers being informed at the same time as you were, it's possible that some of them are still being notified and sifting through all the information that they have to go through. We have a great dealer network - if your dealer doesn't have all the details yet, consider giving them a bit of time to get everything sorted out properly.A lot of logistics involved, and it seems that the public will have its part in educating some of the dealers to make the project run smooth.
when i did the vents on my bike it was 1800 in parts and 550 in painting, this is the second time i am posting this because i can't find the first one i poster. heck it would be nice to get the 1800 back and i will eat the paint and labor
