998cc 2013 RT - can too many LED lights cause Hyperflash?
DelBeeMan
Need Hyperflash Help!
I've gone through the past threads on this and have not been able to find any answer to this.
I have a 2013 RT Ltd and have installed Big Bike Front Fender LED turn lights, TricLed A-arm LED driving/turn lights, and TricLed rear saddlebag LED turn/brake lights. To the turn signal circuit I've added 50W 6Ohm resisters; one to each of the front turn signal circuits and one each to the rear turn signal circuit. The resistors I am using are the gold-anodized-aluminum cased ones with the red wires that you see everywhere. With the resistor wires, I have one end tapped onto the power wire and the other end tapped onto the ground wire.
I'm still getting Hyperflash. :gaah:
Any thoughts from anyone??
Hello Del,
I might be wrong but------- I think the resistor value might be too high. I put my resistors in parallel.
Search Youtube or this site for hyperflash. There is a procedure to correct it. I know I watched a video on it, maybe from LaMonster.
I just installed The brake/run/turn led lights and the showchrome top trunk light on a 2019 RTL. No hyperflash. The instructions I received from Spyderpops does have instructions on how to solve the hyperflash issue starting with the 2014 models.
Their number to call for assistance is 501-760-1234.
Good Luck!
I watched the video from Lamont but the only one I can find is for a 2014 or later model. The 2013 and earlier models do not allow an on-board reset.
