It appears to me the movement of Canister and Ebrake and addition of "pre muffler" ( I do not believe it is a cat) is the cause of our 2013 troubles.
In the 2013 diagram, what are the numbers for the canister, ebrake & pre-muffler. I think I know, but I haven't been that deep into mine yet to know for sure. Also, is it possible to remove the canister altogether?
Thanks for that link. I've bookmarked it. Very helpful.
#20 is the cat. The cat removal kit replaces that part with a 2 into 1 "Y" pipe. That's the kit that costs $450, but I am trying to assess whether the return will be worth the cost.
I spoke with the guy that does the by pass kit and my long term plan is to remove the cat and install the by pass along with an aftermarket pipe and high flow air cleaner. Just need power commander or someone to release a tuner for the 2013 RSS so I can correct the mixture after all the parts are replaced. The bike should run cooler and much stronger or at least I hope it would!
I agree, I have 13 ST and want to remove the cat. can you give me the name and phone number of the guy who does the by pass kit.
Thanks, Bill
No matter what they called it, it is a cat. Can't pass EPA certification without it.But I do not see anything anywhere that says it is a "Cat" the RS has straight pipes. I would like to see somewhere that it is called a cat. I believe it is just a muffler. Lamont or Scotty correct me if I am wrong please.
CATs run hot, but the newer type with a catalytic mesh rather than granular fill runs cooler than the old type. The Spyder CAT is pretty small, too, so produces far less heat than the automotive units referenced. Keep in mind that your exhaust pipes near the engine can ru n at thes temperaturs, and are seldom less than 800 degrees. There is a lot more exhaust exposed under that body than there is CAT. You are still looking at little return for a lot of money and time invested. You are unlikely to get rid of the heat, you can only live with it or try to dilute it or redirect it. You think this thing runs hot? Try an air cooled engine sometime.I've been reading up on catalytic converters and here is a quote that I came across:
"The average light off temperature at which the catalytic converter begins to function ranges from 400 to 600 degrees F. The normal operating temperature can range up to 1,200 to 1,600 degrees F. But as the amount of pollutants in the exhaust go up, so does the converter's operating temperature."
That last sentence has me wondering if it is possibly why some 2013s have heat issues and others don't??? If the cat runs hotter for some reason (plugged, defective, or ?) could this be where the excess heat is coming from that is boiling gas and roasting the driver and passenger? I'm just throwing that out there.
Also, I've been reading that the exhaust manifolds typically run much cooler. On many bikes, they only run around 900 degrees. Again, I'm NOT saying this is fact, but this is why the internet is dangerous![]()
