2011 spyder rt upgrade suspention
I run 30psi in the front an 34psi in the rear. the shocks are set at the max I've lurned to relax more in turns an love the ride so does the better haif . I'am going to have the shop [ Ridenow Ocala,fl ] rotate my tires this sat [roate meaning take the tires off the rims an roate them ] at 5k mi on them I think it's time to do it. I roate my car tires every other oil change an they last a lot longer. I'll let you check them out at the BQ . Hope every one Has a safe trip to the Somkys:2thumbs:
I run 30 psi in the rear tire and as noted on the sidewall, Max air pressure is 30 psi. Not much room for improvement on the rear. My fronts are at 22 psi and never felt the need for more but maybe that is were the Elkas come in.
