So, I recently became a member of the spyder world. I have a 2011 RSS. I read the basics. Don't bog the motor. shift slightly higher its not a harley. so on and so forth. More recently, intermittently, I get CHECK TRANS message on the screen and the typical engine silhouette will turn on. It seems like a combination of other members complaints. I was quite wary of the semi auto trans to begin with, I hope it isn't anything serious. There doesn't appear to be any rhyme or reason to what triggers it. For example, few times wouldn't shift from N to 1 at the start. Then between various gears while riding wouldn't go from 2-3 or 3-4 or so on. Usually will go away then most of the ride with be 100% fine. The gentleman I bought it from didn't disclose any issues and I truly feel this is something new.  I don't tap the button, I hold it until the shift is confirmed. Is there a way to reset the "computer" with like a series of key turns? Could be be from low oil level? Is this step one? The other thing I should mention, a VERY nice quality set of adjustable handlebar risers and grips were installed sometime during his ownership. Does sometimes changing these types of parts mess with switches, are they delicate? The two can am dealers in my area are quite far away from me in the Chicagoland area. So before get nuts and run to them, is there any sort of steps I can perform myself to troubleshoot something like this?
As I mentioned, it seems to be a combination of complaints from other forum members that triggered this message for them. Furthermore, don't want to give the shop 100$ for them to go, well turn the key on and off twice and you should be good... Input would be greatly appreciate since Im new to the spider. Thank you all in advance.
