2011 adding LEDs
Large1
I have LEDs to put on the mirrors and looking at Spyderpopps Bright Fear lighting Kit, Now I see I may have a problem as in Hyperflash, Anyone that has had them on a 2011 did you have a problem and what is the fix if any
Signal mirrors and LEDs
I installed signal mirrors on my "14 RTS and even though I tried the button holding method of of stopping the hyper flash , it didn't hold. I put in resistors and never looked back.
HYPERFLASH causes::::::::::::::::: Kaos
PS: button holding method is only for 14 and newer.
Interesting. ...
I added turn signal LED's and additional brake LED's and wired them to the corresponding wiring in the harness and never had an issue with the hyperflashing. As long as the system has the standard working bulbs in line you will not have a problem. If you change all the bulbs to LED then you will have issues. :thumbup:
Thanks for the input
I have spent two days trying to search for the information about the extra LEDs on the 2011 I see you have a 2012 listed so it should be the same system, Now comes the fun in removing all the panels but oh will we got more snow today to ad to what we have had for 2+ month so looks like i have time
Update
So far so good installed the LEDs under the mirrors, At first I had a flashing problem (Two fast and 0ne normal) then it settled out to flashing normal. Now to the back for the next step,
