2010 RS Coolant Change
WisconsinDavid
Getting ready to do some service on the Spyder. This will be my first time doing coolant service since I purchased it used. Any tips, tricks, caveats on the 998 coolant system? Thanks. Also, which coolant do you use... guessing anything aluminum friendly is okay!
Be aware that removing the radiator drain plug can be disastrous. Some from that era detached themselves from the radiator, which required removal and replacement or if out of warranty, repair. Because of this, most, remove the lower radiator hose to drain the system.
That said, after this happened to mine at the dealers, I stopped draining the system altogether. Instead, I evacuate the reservoir once a month and replenish with 32 ounces of "50/50 Prestone Yellow"(ENGINE COLD). To accelerate a full replacement in this manner, one could do it once a week or after every ride until they have for the most part introduced all fresh coolant. It's so much easier this way. And, if you have any doubt about how well it works, NAPA sells coolant test strips that will settle those fears.
That said, after this happened to mine at the dealers, I stopped draining the system altogether. Instead, I evacuate the reservoir once a month and replenish with 32 ounces of "50/50 Prestone Yellow" once a month. To accelerate a full replacement in this manner, one could do it once a week or after every ride until they have for the most part introduced all fresh coolant. It's so much easier this way. And, if you have any doubt about how well it works, NAPA sells coolant test strips that will settle those fears.
I never thought about doing it that way.You just saved me a bunch of money Jeriatric. Thanks a bunch for the idea. Also did not know about the test strips at NAPA.They always come thru.
I'm getting a coolant reservoir replaced this weekend cause its cracked. Should I ask the dealer about draining from lower hose instead of plug? I have a 2009 GS se5. Thanks
I would probably suck the coolant down from the reservoir with a "sucker". That should get enough out to change the reservoir. But dealer is doing the work so they should know not to use the drain plug. If they do use it and it breaks the pressfit connection they'll just have to fix it. Should be no cost to you but will take more time to get your bike back.
Thanks for reply. I'd rather be safe and I'll ask. Its my only ride. Rather not have any longer down time
Good luck with that. The dealer will blame you for over-tightening it!
