2010 Can-Am STS
Scorp
My Spyder Is stuck in neutral. The gears seem to be shifting but I can’t get it out of neutral. Any suggestions would be appreciated
Umm just nit picking but the ST line up wasn’t till ‘13 so guessing is a RS :dontknow:
& if is the SE check the linkage by left peg (when on the bike) may be loose. Follow to where meets transmission & see if you can manually put in a gear (just push or pull don’t unbolt anything yet)
Update?:dontknow::dontknow:
Hmmm, New member joined March 22; about 1.5-2 hours later, posted the same thing twice (see above for 2nd try); then the profile shows the members last activity was about 3 mins after that; and Scorp has apparently not been back since?! :dontknow:
